1 - 3 of 3 Posts
didn't like the sound of the original horn so i headed off to harbor freight this a.m. found a twin chrome horn set for $9.99. both high and low sounded the same to me so i used the low. original bracket and connectors were used,a dap of locktite and done. about a 10 minute job.sounds louder and more base. i believe with a single horn i should be all right without the relay.
http://www.harborfreight.com/2-piece-12-volt-electric-horn-set-99911.html
agreed, but i just couldn't stand that cheap beep sound !!
probably a little more volume but with a quality type sound now. cheap quick fix. in the winter i will put more thought and effort into it.
i wanted to install an aooogah horn on it like my truck but there just didn't seem like enough room. the aooogah isn't that loud either.
it is different from what people normally hear on the streets so it always gets attention !!
1 - 3 of 3 Posts
