When I slide a stick of 1/8 TIG wire through the primary filler plug and down behind the chain to the bottom of the case to check primary oil level Im only getting ~1/8" on the stick. Im quite certain getting all the way to bottom of case and checked it before and after a ride this morning and its the same. I rebuilt my clutch a month ago but I do not remember pulling the 71-1072 breather baffle plate so I dont think I could have pulled that oiler line off (assuming it has one). I also just noticed my 71-1072 Breather Baffle Plate doesnt have an oil "tray" like online replacement parts which show it but as mentioned (see photo) mine doesnt have one nor do I see a hole where the oil would come through even if it had the tray.
My parts manual shows what appears to be the tray and all replacement parts online show it. (I also looked in the '79 parts book and it shows it as well)
Anyway, should the plate installed on my bike have a tray or at least a hole in that vicinity for that brazed tube to flow oil through into the primary?
If not how/where does the oil flow into my primary?
Any ideas as to why it only measures 1/8"?
(Maybe Im looking at this breather plate all wrong... i seem to do that a lot lately...must be the damn heat here!)
Since I lapped my primary cover and installed new gasket I have not had any leaking or oily mess anywhere under the primary, rear rim, chain/sprocket and left muffler area as before and all are clean. 20 miles out on ride today I fueled up and looked for any signs of leaks on the concrete pad at the pump and not a drop. About every ride where I can I'll sit at a stop for a few then roll back and look for leaks and nothing noted so I don think i have any massive leakage while under way.
Thanks for any help. LM
