1,300 original miles, until this month, the bike hasn't been ridden since 75'.
Here is the problem:
Bike starts right up and runs absolutely perfect for about 30 mins. Once it gets hot, (I'd say normal operating temp) it loses all bottom end. It will still run normal speeds if you are cruising, but pretty much zero throttle response, and very sluggish if at a stop.
So I've torqued the head, adjusted the valves, new plugs and rebuilt the carbs. I've also adjusted the points at 3 different positions, but still the same outcome.
I've searched the net, but haven't found anything useful. Does anyone have any suggestions!?
Thanks!
Michael
[email protected]
Thanks!
Michael
[email protected]
