It's a 930/60 according to the 1972 factory parts book and Amal's website.Do you happen to know the correct numbers written on the carb or will any 30 mm suffice ? I want to order a new premier from the uk and there are several 30mm options. Also, it seems like a 3.0 slide is recommended ?
Lowbrow has them in Ohio with the right jetting and the Bonneville Shop tooDo you happen to know the correct numbers written on the carb or will any 30 mm suffice ? I want to order a new premier from the uk and there are several 30mm options. Also, it seems like a 3.0 slide is recommended ?
Given by definition there is a maker, why wouldn't you ask them; why would a bunch of opinionated old farts on an internet forum know better?want to order a new premier
The 3 slide is richer than the 3&1/2.the 3 1/2 slide seems fine, but who knows? The 3 may be better (a little leaner from 1/4-1/2 throttle)
No hesitation whatsoever and I stand corrected! Thanks, Mick and TTIf the 3 1/2 is not giving hesitation from idle, then there's no point in going to 3, as TT says, 3 is richer.
