41 - 55 of 55 Posts
AFAIk there are only two types of OIF USA tank ( slimline)
the earlier ones and the later (seamless) ones.
Your bike looks amazing, what a cool ride!
I bet those pipes sound incredible.
Nice work man.
Discussion Starter · #43 · (Edited)
It got some rides, and mostly sat while i was doing some travel. Rego ran out so i went to do a few odd jobs and re-register, only to notice a knock movement in main-shaft.
Stripped it down and had full bottom end reubuild done a couple years ago. Scrubbed out the frame and got the engine offered up and fitted with new fixings, and that's where it's sat since. work and life got in the way.
Trying to muster some motivation again to complete it - will be a fully rebuilt bike by the time its done, all bar checking the frame for straightness and repainting.
A few additional projects have half-started, such as fitting an oil-pressure guage, norton style external oil filter below swingarm, mini kill-switch via relay, rebuilding the rocker boxes, and and exhaust to something that will accept some mufflers. I'd also like to see if i can to convert the higher output bates KD lamp bulb to LED to help the battery/charging system, but as I never intend to do much night riding, I will get to that eventually...
Tire Wheel Automotive fuel system Fuel tank Vehicle
Discussion Starter · #44 ·
Picked up some parts yesterday. Pair of cocktail exhaust mufflers to appease rego and my ears.
In process of fitting an oil pressure gauge, I’ve grabbed a tap & die to figure out this nps/npt adapting properly - with the thought I’d rework a tee piece, keep the idiot light in dash and engine-mount the gauge down low but somewhere in view at a glance…
but, im now stuck with decisions again…:
1. Go minimalist cockpit and run a tee, with idiot light and maybe even one of those sparkbright style charging voltage monitor LED’s to go with it.
or,
2. lose the idiot lights altogether and just run the little gauge up in the cockpit instead of down on engine, maybe with a mini chrome speedo to match it (opens more challenges with speedo gearing, I just bloody went and replaced the rear hub speedo drive gear with a new emgo repop 25:1 too… -.- )
it’d be a bit modern and run of the mill cafe-racer -esque to have a cheapo mini-speedo I know, but I had no speedo at all prior. I just went with the traffic and had a pretty good feel of gear and engine revs for the main speed limits, and always erring on side of caution with how fast I was going.
(Forgetting the bobber factor for a second); I’ve just always loved the clean cockpit on this factory metalworks beesa and would really love to run it more stripped back like this but know it’s not the most practical. The Less to look at, the better one can enjoy the road, I really feel.
Wheel Bicycle frame Tire Bicycle handlebar Bicycle tire
Also going to switch back to the standard bars as the low rise put a bit too much weight on the hands
Discussion Starter · #45 ·
Question for the gurus, knowing the bike had a lot of original parts still in it (never rebuilt) but also that a lot of it was over due/flogged out, I’ve half a mind to replace the carbs.
Just dreading the tuning process after the fresh rebuild and needing running in proper, but don’t like replacing things for the sake of it.
At what stage are slides/carb bodies just too loose or flogged out to attempt to deal with? Bite the bullet, replace em and be done with it?
or have another go with the originals but now on fresh cables. and if still too fiddly then fork the $600+ ?
am I over thinking the engine idling too long before being run-in, while tuning after a fresh rebuild?
If you've gone top to bottom, inside out on the carbs, with 100% certainty, and it's still not running right, YES, you PROBABLY need new carbs.
HOWEVER, you'd best be bloody sure EVERY other system is operating at 100%- ignition, battery, valves, timing, etc.
There has been more than one report of a person installing brand new Amal Premiers (after cleaning them), and STILL having issues. If I remember correctly it's almost always something in the ignition, silly things like resistor caps AND resistor plugs (that's a no-no).
You can run the engine while tuning, but use a big fan blowing on the front of the engine. Limit it to a few minutes at a time.
Discussion Starter · #47 ·
Remounted the original? Western bars for better height. An example of how I had the Lucas warning light tubes fitted - perfect snug tight into the wire fork-mount holes in the top yoke. Have my oil light in one and considered putteing a voltage indicator mounted inside the other.
Wheel Hood Automotive tire Motor vehicle Automotive lighting
Automotive fuel system Motor vehicle Automotive lighting Automotive tire Hood
Always freaking at the thought of carb slides sticking, and having to reach under my leg for the key, I fit the smallest kill switch (engine run switch - ie it’s not “momentary”), runs via a simple relay mounted in frame void between gussets behind head tube.
Automotive lighting Product Automotive exhaust Automotive tire Automotive design
And mocking up what cluttering up the front will look like if I ditch the warning lights, and use those holes for some brackets to mount the pressure gauge and speedo.
Rather keep it bare, but probably most practical…
Speedometer Wheel Bicycle handlebar Automotive tire Automotive lighting
Discussion Starter · #48 ·
Todays job, rebuilding rocker boxes. Need to work out what order all these washers went in. Seems to be a lot of copper ones not sure if that was correct…
Crankset Automotive tire Gas Font Bicycle part
Discussion Starter · #49 · (Edited)
Rewinding things back a step, just found a bunch of pics from the engine rebuild. After reading @Dr. Zo build thread I’d wished I’d seen the alternator rotor/hub wobble issue prior to getting a full rebuild.
none the less happy to have had it done as it needed it.
Automotive tire Motor vehicle Gas Fastener Screw
Rim Household hardware Bicycle part Gas Automotive wheel system
Automotive exhaust Cylinder Wood Gas Gun accessory
Automotive tire Motor vehicle Automotive design Gas Rim
Digital camera Camera lens Camera Point-and-shoot camera Reflex camera
sludge trap wasn’t too bad or too blocked up. Crank nose needed dressing due to someone taking to it with a hammer.
after having it apart and starting to go back together, engine builder realised jugs needed another rebore. Previous machine shop I used was a modern bike shop, fine grit smooth hone, tight tolerances, and left a some pitting in the bores which just wouldn’t fly. So another top end rebore now from 40thou to 60. and pistons & rings went in. In hindsight, wished I’d known about pitting and severity at the start, and considered a morgo 750 from the get go…
Motor vehicle Hood Automotive tire Automotive design Vehicle
Motor vehicle Automotive tire Automotive design Automotive wheel system Engineering
My 71 is with the 4speed and 47t rear. I upped engine sprocket to a 20 tooth.
I’ve not got it back together yet but already to tell for sure, but already wished I listened to the British bike mech and went up to the 21t like he’d suggested while it was apart, won’t get a taller gear in there now without pulling down gearbox again ( I won’t cut/notch the case)… and now I’m already of the idea the gearing change mightn’t be enough for my liking with the 20t…
Still Learning lessons, always too late …
Hi,
Can of worms, for various reasons ... :mad:
washers
There should be only four copper washers total, one each side of each feed banjo.
In theory, there is a sketch in the '71/'72 workshop manual; in practice it's wrong ... :mad: (shows the pre-'68 assembly order).
You should follow the order shown in the '72 parts book - (hardened steel) plain washer each side of each rocker, Thackeray washer between plain washer and side of rocker-box. However, even that isn't completely correct, :rolleyes: it continues to show/list the 3/8" ID (E1330) washer at the feed end of each shaft; you'll need to replace each with another E1575 (1/2" ID).
Nevertheless, before beginning assembly, you'll need to decide whether to have the rocker shafts 'grooved', which should :mad: have been done since the '68 changes ...
Background
During '68, BSA R&D at Umberslade Hall advised a number of changes, primarily to avoid the cost of drilling rocker arms (which could also weaken them) and pushrod balls for lubrication.
Meriden made that change but - imho in a pretty-poor abdication of management responsibility - didn't make the associated changes to either rocker shafts (machining an oil transfer scroll on the shaft) or the washers assembly order, both of which were necessary to maintain the lubrication previously supplied through the aforementioned drillings. The result is, while the rockers and actuation continues to 'work', it isn't for as long. :(
@Shippy posted he had a straight oil-transfer groove cut in his 500's rocker shafts with a simple Dremel.
Hth.
Discussion Starter · #51 ·
Thanks Stuart! Yes so it seems.
I made a thread last year with a few queries which I’ve booked marked, there’s posts and links in there with lots of great info - albeit a confusing can of worms as you mentioned, due to all the models/washer & groove iterations, and opinions on alternate (updated) methods;
Hair Hairstyle White Product Human
I don’t think I’ll opt to cut grooves in shafts. I think I’ll read, and re-read, and just opt to go with the most ideal washer setup with the standard solid (un-cut) rocker arms and shafts (which I think is very much as per your suggestion above ie losing the 3/8 washer).
Thanks for clarification!!
Discussion Starter · #52 ·
Little more progress on the oil gauge idea - teeing to run a pressure switch. @TR7RVMan made a good suggestion, to try testing my pressure switch. Had a fiddle this arvo with a test light, tapped a nps theread inside a blank end of a bsp fitting I won’t use, and offered it up in a bike pump on a battery.
I read somewhere the switches are set for 7-11psi. gauge wasn’t very detailed at lower pressures, but I reckon it barely pushed 7 before switching. Likely around 5, too low for my liking!
Automotive tire Automotive lighting Asphalt Circuit component Composite material
Also reading around that at revs it’s can be in the 50-80lbs, and in the 20-25 at idle. Given this would it be that bad an idea to fit a generic switch more suited, say one preset for 20psi… ?
When I first got my beater '67 Bonnie "bomber" (rattle can black, leaking oil everywhere and smoking badly) I must have ridden it a year without sufficient oil getting to the rockers. Didn't seem to hurt or even discolor anything... Same parts went back in when I restored it, and it was still humming right along when I sold it almost 25 years later.
Hi,
oil gauge
Depends. Your photo. shows you're testing a pattern switch, not an original Smiths. If that pattern switch is NPS thread, it's sold as a replacement for the '74-on switch, which Smiths supposedly rated for 3 psi ...
It would be a bad idea, unless you want to be freaked after every spirited run in hot weather ... :sneaky: then the pressure can fall well below 20 psi, although still be perfectly-adequate.
The whole idea of oil pressure switches on Triumphs and BSA's was a mortally-stupid one, because no-one actually knew how widely the oil pressure varied between hot tickover and cold maximum. :oops: Cue dealers inundated with punters complaining about oil pressure warning lamps flashing at tickover on their new bikes; strip-downs rarely if ever found any lubrication-related problems; cue the factories fitting lower- and lower-pressure switches ... 😖 Otoh, if a twin runs 50-60 psi above about 3,500 rpm when hot (and a triple 70-85 psi), if an OPW lamp switched by even a 20 psi switch comes on when the engine's above that 3,500 rpm, the engine's donald already. 😖
If an engine maker's going to fit an oil pressure switch, far-and-away the more-important manufacturing requirement is consistently-good oil pressure at all rpm for hundreds of thousands of miles in every engine made. For this reason, engine makers apart from Meriden haven't fitted feeble plunger oil pumps for decades,
If you're running an old Britbike, knowing you'll never have consistently-good oil pressure at all rpm for hundreds of thousands of miles, if you must be able to monitor pressure in real-time, only a gauge works. However, then you must learn what the gauge is telling you - e.g. after the aforementioned "spirited run in hot weather", the pressure from particularly a twin's weedy oil pump will be lower than what even the Triumph workshop manuals say. Is it a problem? Only you'll know by stripping your engine ... :sneaky:
Hth.
Discussion Starter · #55 ·
Right then.
bugger the switch, even runnin a gauge now makes me feel it’ll just be “in my face/on my mind” the whole time.
I’ll build it, mount a gauge out of the way for periodic monitoring now that it has an oil filter, and just ride the thing. At the rate I’ve been moving with rebuilding this thing it’s not like I’ll manage to have it ridden daily :(
41 - 55 of 55 Posts
