Those wires are for connecting a ignition capicator(2MC)inline. On this model it is mounted under the battey holder by use of a big spring, Correct fuse is a Lucas 35AMP fuse (17.5AMP constantdraw) or a SFE20 anything larger is not reccommended. DO NOT USE A US 35AMP RATED FUSE THE UK/US RATINGS A NOT THE SAME. Littlefuse does make a fuse called a UK35 which is probably a cross to the Lucas one but I dont know that for a fact.
