Greetings, Rod from San Angelo Tx. I just traded a sailboat for a 69 TR6R Triumph. First question is what is it? A Tiger, Bonny or Trophy? The Serial Number starts with CC123456TR6R? Second question I know it needs a clutch basket/hub-- any recomms on where to purchase one and should I replace clutch plates at the same time. Been sitting about 7 years but I did get it started for a bit before I think I have a gummed up carb? I asked to same question to one of the senior members of this forum previously before I found this and joined. Appreciate any info. Semper fi rod
[email protected]
Hey, I think it's a Trophy.
How do you know it needs a clutch basket? If the grooves are just a bit rough and not deeply saw-toothed, you can just dress them up with a Dremel tool.
You need to have a look at the friction plates to see if the raised pads still have at least a 64th. Also, check the plain plates for flatness on a glass pane.
The hub can do with only the inner rubber cush pads replaced rather than the entire unit.
Try Rabers & Baxters, plus a half-dozen other high profile reseller / stockists.
You're much better off with an old Triumph than with a sailboat ...
The 'CC' in the serial means it was built in March of '69. The serial number itself seems a little contrived to me ... I've never actually seen a '123456' before ... TR6R is a low pipe single carb 650.
After sitting that long, you should definitely go through the carburetor. If it has the original (or a replacement) Amal on it, the carby is VERY simple. Just order up a rebuild kit and go for it.
If you don't yet have a service manual and a parts manual, order them.
Most importantly, where are the pics of this fine old Triumph?
Tr6r
Greetings and thanks for all the good info. I feel better now. I owned a Trophy 500 (pipes up on the left side) when I was stationed in Puerto Rico. Great bike. The exact serial number for this bike is CC13123TR6R. Believe the original color was a deep plumb/burgendy color?? I havent pulled the primary off but only went on what the original owner told me. I have it up on the lift now and cleaned it all up. Actually looks pretty good. Have a bunch of small stuff to replace, repaint etc but need to address the clutch issues and of course the carb when I get the time. If ya'll every up in the San Angelo area, pls stop in or give me a shout. Semper fi rod
