1 - 7 of 7 Posts
Hi sangalfie,
If you have a look in the back of your parts book it will list the P/Ns for the tool kit. For my 72 it lists the following:
D2112 Toolkit Complete
D291 Tool Roll
D2184 Damper Unit spanner (C Spanner)
D1911 Tommy Bar
D2084 Spanner - open ended
D971 Box Spanner
D972 Ring spanner
D974 Tyre valve key
D767 Screwdriver
I hope this helps, although I have no idea if you can still buy the tools new.
Webby
Hi sangalfie,
D291 Tool Roll
D1911 Tommy Bar
D971 Box Spanner
D972 Ring spanner
D974 Tyre valve key
D767 Screwdriver
Webby
What's a "Tommy Bar"? Sounds like something the German Infantry carried around during WW2. :D
It is a lever of sorts. I think in this case it would be put through the hole in the axle to keep it from turning when loosening or tightening the axle nut, or it might be a small one to put through a hole in, say a spark plug socket.
1 - 7 of 7 Posts
