1 - 11 of 11 Posts
I have really enjoyed my recently acquired 2007 T-100. A fantastic bike!
But on most rides I fined myself at least once trying to find a non existent 6th gear.
Just me ?
Put a 19 tooth sprocket on the front and most likely you'll stop hunting for a 6th gear. Can't remember the last time I tried to find 6th gear since doing so. Quite a debate about changing from an 18 to 19 tooth sprocket. Some really like it. Others don't.
Something to think about.
Karl
just leave it alone and you will get used to it. 19 teeth is too woosified.
i may go to 17 teeth 'cuza my hack.
andody know the bestest plase to acquire one?
thx,
goo
If you have a rev-counter you'll notice that at most highway speeds the two instrument needles travel more or less parallel to each other.
A quick glance at the instruments tells you you're in top gear.
+1, yes thats what I do most of the time.
Plasma.
I've found I do this too, usually on the AM & PM commutes. Traffic at those times is usually above 60-65, and at least once a day I find myself wishing for one more gear.
That said, I like the gearing ratios in general in all other riding circumstances.
when I first got my bike I was had the same concern. But it faded quickly as I stopped baby-ing the motor. Most of my riding is on local parkways, that is six lane divided roads. so I am up to 60 ish and back repeatedly.Really I am in third gear for the most part, cruising about 55 mph. I only use fifth gear on the freeway. So what I have found best for me, is to cruise the bike at around 4000 rpm, not down around 3500. there is a sweet spot there the whole drive train seems to be very smooth. I am running about 4200 rpm at 80 mph depending the wind.
i don't even got a rev counter. my harley don't, neither. my norton and beemer do but it ain't a big deal.
the less stuff you got to look at, the safer you is.
For the type of bike and the torque range it has, IMHO there is no need for a sixth gear. Indeed, on many bikes it seems more of a marketing ploy than necessity.
That's my two-cents worth any-hows!
1 - 11 of 11 Posts
