I took the 95 Thunderbird for a ride today and after about 10 miles of mostly highway speeds I was headed towards home and going 55-60 mph the bike sounded like it was cutting on and off, with the wind noise in the helmet I figured it just the wind drowning out the engine noise. As I approached a stop sign I started to slow and the engine sputtered and stopped. Coasted to a stop, started the bike and it idled rough and gave her some gas and it sounded rough. Shut her down and got off the bike to see if I could see anything leaking from the radiator or crank case, nothing. Started it up and it ran fine the rest of the way home (about 4 miles). What does this mean? Do I need Nology coils? Pickup coil? This bike has run without a hitch since I purchased her at the end of May.
last time I filled up I heard air rush in when I loosened the cap, does that mean anything??? If so, what to do?
The vent for the tank is built in to the gas cap.
If it is not venting properly and a vacuum builds up in the tank then the gas cannot flow into the carbs.
There is an overflow tube and it has a one way valve. Tip over valve prevents the fuel from running out of the tank in a tip over situation. Some remove that valve, to let that be the tank vent. Not the best idea, but it will solve your problem.
Re the tip over valve, I used to have the same hissing of air rushing in (negative pressure when I loosened the fuel cap when refilling. (I never had any fuel starvation problems, tho' I've had a non-stock locking cap almost since I bought the bike.)
After much sucking & blowing from both ends in all manner of contortions & much head scratching (would have been funny to watch :D ) I finally decided I had the valve the wrong way up.
This photo shows the correct orientation: (lying next to my super duper ZX6R shock)
The pipe is also easily pinched when refitting the tank btw.
If the problem isn't solved after checking this, I would check fuel flow thru' the tap & filters (not forgetting the 'duck bill' filter at the carb end). These are the most likely if the loss of power is gradual and/or cuts in & out. If that doesn't cure I would suspect the ignition crankshaft sensor aka pick up coil (under r/side crank cover) - this is more likely perhaps if the cut out is sudden & complete & the bike won't restart until the engine is cool. (Not had this myself, but these are classic symptoms from other T3 owners.)
