I have started to have a starting issue with my 52 plate Tiger, I believe it is electrical as it is intermittent aqnd would like a little help if you have experienced a similier issue. It will not always start on the button. Ignition lights up the wurr of the fuel pump can be heard but there is nothing on the starter. Turn her off a couple of times and keep trying and eventually she fires up and we have no problems. I have cleaned the switches on the starter motor and solienoid and start button and also the clutch. I have removed the starting switch loom and cleaned all the connections and still we have this problem. I did notice though that the relays on the left hand side front, the third or second one would occasionally click if you hit the starter button without the clutch in and everyso often would be silent, but when it clicked you could pull the clutch in and she would start, The question is has anyone had the same problem and how did you fix it and secondly what is this relay for ???
