Did i see this somewhere on the hinkley classic triple forum?
Is this a known issue, a short or what? Thanks in advance for any help.
This false temp thing was an issue with my '02 T-Bird, and learned it is fairly common, requiring some simple wiring changes. Had mine fixed by Manayunk Triumph. Unfortunately I don't remember the specific fix, but Buzz at Manayunk gave me a diagram with the fix described (it may have been a tech service bulletin). After it was fixed, I don't remember if I kept it. You might try a search on this site.
The temperature trigger is in the wiring harness the problem can probably be fixed by checking the connections inside the headlamp, probably a poor connection. I believe Triumph sent out a mod for an earthing problem.
Ride on ! :)
