The gigantic California Compliant turn signals had to go. I replaced them with the tiny Rizoma Club signals front and back. According to this PDF you can choose 1 of 4 options for "activating" new turn signals. https://www.triumphinstructions.com/ProdDocs/A9838023-EN.pdf I thought I would try this simple solution to the rapid flashing issue before adding resistors (actually larger than the turn signals themselves) and take too much space. I did everything according to the instructions but as soon as I let go of the i (info) button when "TYPE" pops up on the display it just goes to the normal screen and I can't change anything. Anyone else try the i-button with this issue?
I changed the std signals on my TTR to led’s made by Triumph only sold in the UK. Changing the signal mode was easy and done with the i button. It won’t work on after market signals. Resistors are needed.
After about the 10th try the info button worked and I could change the settings but you’re right it didn’t help. Will have to find space to wire up some resistors.
I've had aftermarket bullet style LED signals on my '16 TTR for 3 years with zero issues and no resistors installed at the stealership upon delivery. After I added the New Rage tail tidy I used the "i" button to set the flash rate without issue. Not sure why resistors are needed, but I'm sure you'll get it sorted out.
Sent from my SM-N960U using Tapatalk
I have installed Rizoma Clubs, Watsen Designs and motogadget LED signals on T120s.
Changing the selection via the info button has worked on them all. (No resistors needed.)
Same here. I have Rizoma Clubs on my R and I could change the flashing speed via software, no resistors needed. The TFC shouldn't be any different.
