1 - 2 of 2 Posts
Guys,
my 2016 triumph scrambler engine failed on me at 50k due to a bad oil pump gear. Now I’m looking at doing an engine swap.
I know that the Bonnie/ thruxton engines will not work without some wire harness and coil work but since the speed master is a 270 will it work?
I’ve done a little research and it seems most part numbers line up. Except the inlet camshaft is not the correct part number.
any help is appreciated, trying to get a new engine in before a 2 month motorcycle road trip across the US later this year
Any of the 270 degree motors (America/Speedmaster/Scrambler) will go straight in with no modifications. Just make sure you get get one of the later CANBUS models (2012 onwards I think?)
Tim
1 - 2 of 2 Posts
