After pulling the stock bar end mirror I found that my - British Customs Bar End Mirror Adapter (Part Number: BC201-007)
Will not work....
I'm sure others have changed theirs out, And Ive looked for after market ones.
Any suggestions?
Edit: Why exactly do they not fit?
If they are like the CRG bar end mirror adapters I had where the bolt was too narrow and not the right size, you will need to go to your local hardware store and buy new countersunk bolts that are the right diameter and thread pitch to fit the threaded insert inside the bar.
You'll then have to drill out the center of the adapters to fit the bigger bolt.
That's what I had to do to run the CRG adapters on my stock handlebar.
No worries, its such a simple fix but it took me a while to figure it out too lol.
