Hi folks,
Over the last few weeks my bike started displaying strange symptoms. At first it was cutting out at very low speed or while stationary. I thought it was completely dead until a few days ago when it happened and I accidently pressed the horn button. It worked. The lights were also still on but the speedo and tacho were dead. When I straightened the front wheel they came back to life as did the fuel pump. I searched the forums and found I wasn't alone! One suggested cause was the crimp joints in the wiring loom. I duly stripped the front of the loom and soldered all of the crimps (no breaks found!) I reconnected everything and the intermittent fault was still there . Eventually I realised that the multiway connector to the dials seemed to be suspect. I opened it up to find 6 connections. I removed them one at a time using a 1mm watchmakers screwdriver and inserted the driver under each of the spring contacts before pushing them out with a ¼ turn of the driver. I then scraped clean the male spades on the other connector. On reconnecting the two parts everything was functional once again so I rewrapped the loom and reassembled everything. The bike starts first time again and doesn't cut out on a left turn!
The bike may be nearly 9 years old but it has only done 2600 miles from new! Dodgy connectors!
David
Circuit component Hardware programmer Electrical wiring Electronic component Electronic engineering
Thanks Rich!
LOL and it only took me a day! Glad I wasn't paying for labour! I couldn't believe that there were crimp connections hidden in the loom but hopefully I've headed off any problems with them! Three of the other connector blocks have ¼" spade connectors in them eg the ignition connector. I don't think they will have any conduction problems.
David
