So I was out riding the other day and everything was fine. Shut the bike off to run inside for a bit and came back out -- and it won't start. When I press the start button, the headlight and dash lights turn off (as expected), and I can hear what I think is the starter relay clicking, but there is absolutely nothing from the starter itself. Just silence.
Out of an abundance of caution I completely replaced the battery with a brand new (and tested) one. Same thing.
I was able to bump start the bike and it ran fine.
Thoughts? Nothing happened to "cause" this, so I am at a loss. Possible the starter just died on me?
Check the wiring for the ignition running by the headstock, a few 2011s seem to have similar issues to the previous models where the wires are too short and crack/break over time.
You can try moving the bars/forks back and forth lock-to-lock while pushing the starter and see if it starts when the wiring is in one position vs. another.
my 08' starter button housing was rotating around the bars and the wires were mashed against a bolt. Maybe your wires are crimped at the housing or possible poor contact at the starter button. Just a thought
Won't be the button, or the lights wouldn't go out. Does the fuel pump prime when the key is turned on? Silly, but have to ask - Kill switch in run position? I have done that before.
