1 - 3 of 3 Posts
Just curious who else has a similar model / exhaust in Australia and which map they are using ?
How are you finding it and what other maps have you tried previously ?
Hi
Surprised you have had no response? Unless I can’t see em?
I have a 2014 R with low boy and triumph / tuneecu no. 20524 which works very well.
Recently had a dyno run and remap.
Before the remap the torque curve was flat and consistent at 74 ftlbs and the power curve straight and consistent up to 124 bhp at 9250 rpm
After tge custom tune I got the same flat torque upped to 77ftlbs and same power curve with slight increase to 129 bhp at an increased rpm of 9500.
The improvement was very slight so I deduced that the original triumph tune is pretty good for this set up.
Aus and UK fuel is not so different is it? 5% ethanol and 95 Ron unleaded in UK.
Taff
2011 Speed Triple Low Arrow - map for Australia
PS map 20525 is for lowboy with 91 ron if that’s what you have?
You can see all the Triumph maps on tuneecu website and download the right one for your vin.
1 - 3 of 3 Posts
