1 - 2 of 2 Posts
Hi assistance required please , will the 09 thruxton run without the instrument cluster plugged in ? How important is the MIL / fuel light connector and does this require connection to start the bike
If it's the mechanical speedo model, no worries. If it has a LCD odometer readout it's a problem but you should be right if it's built in 2009.. There's a 3 pin connector that plugs into the speedo in the headlight housing which is the MIL light and fuel light connection. It's possible to run extenal LED indicator lights for the MIL and fuel using this output, The 3rd pin is a common earth.
1 - 2 of 2 Posts
