Horse Power
Does it matter that much......
what I mean to say, is for all those waiting for a "new 'Tona", it is still pretty poor for a 1050cc engine........comparitively speaking, seeing as how Triumph managed to sneak 148 ponies into the old 955i version.........what gives????..................
surely something can be done to the bigger engine to produce at least 158... which would put it pretty close to any of the (earlier) jap 4 cyl, 1 litre motahs.....
Seeing this was a thread I started with an innocent question.
I would like to make a comment about horse power.
With a side note the Daytona 955 engine produced it's hp higher in the rev range than the Sprint.
The 955 and 1050 Sprints have a pretty much perfect power delivery and torque curve, pretty much a straight 45 degree line.
It doesn't get a lot better than that for fast cornering.
Anyway back to my first sentence HP.
The guys I regularly ride with ride the following machines;
Kawasaki ZX10 2005
Suzuki GSX R750 2005 (a near perfect sports bike IMHO)
Yamaha YZF 1000 modified by an expert tech.
Yamaha R1 2008
2 of these riders are racers, all these bikes make far more HP than my much heavier and older 955i 2004 Sprint ST.........................and yet I can hold my own with them all on the road in the corners a lot of the time, I am by no means the best or fastest rider of the bunch and I have no racing experience.
How and why?
Because exiting a corner, any corner you can only use so much horse power, I have an advantage on certain bumpy roads because the more powerful sports bikes get the front wheel in the air so easily (especially on bumps) and this limits how much throttle they can use, where I can use ALL of my power and torque in these same corners.
It's pretty hard to steer at 45 degree angle when the front wheel lifts!
So when you complain about lack of hp it is all relative to what you want your bike for.
If you want to drag race other bikes well then hp will make a lot of difference, if you want to have a ball in the corners, then useable power and buckets of torque make the job so much easier.
If you are on a track, then naturally on straights more hp is going to win over a lesser powered machine on the straights.
But most of us ride on the road and frankly all that hp makes bugger all difference if you ride your bike to enjoy corners.
125hp sounds like plenty to me.
my 2 cents worth.
DaveM
