1 - 16 of 16 Posts
I've scoured the forums and my owners manual and can't find out what the gap on the stock NGK plugs is supposed to be. Since I have them out while I'm checking valve clearances, I figured it'd be nice to check/adjust them if necessary.
Thanks,
Sparky
Thanks, Slinky...:)
Bringing this topic back from the dead, does anyone know what the stock ngk plugs come out of the box with in terms of gap?
I (without thinking) just popped the NGK DPR8EA-9's in without even checking the gap :D
Out of the box, they usually seem to be within spec. I've only had to make minor tweaks here and there. Best to pull yours and make sure they're right, though.
Just got a set of NGK Iridiums (DPR8EIX-9). They're set to 0.350 from NGK. So these need a considerable amount of gapping.
Discussion Starter #11
Now that you mention it, I think I did the same thing. And mine were shipped not each in their own box, but both in a plastic bag, which was shipped in a box full of parts. Lot's of banging around to do. Gonna check 'em out tonight.
Thanks!
-Sparky
inches/mm
Metric strikes again!
In which case, nevermind.
The NGK Iridiums I just bought were factory gapped to about 0.875MM.
Thanks for the catch vitesse, I almost put them in the bike gapped in inches!
I think he means .035" which is about .875mm.
The dash no relates to the gap size. No need to set the gap these days.
I believe that to be the case with *most* plugs for any vehicle --- cars or bikes.
But I had also swapped out for Nology Hotwire Spark Plug Wires, and the instructions for these Plug Wires specifically cautioned for having the right gap… Granted the right gap was set from the manufacturer, I still felt it important to double-check.
We all have been confused at times. It's only number....right?
I replaced my Daytona plugs with NGK and the gap for all three was too tight. They were good for my Thrux. Pays to check.
1 - 16 of 16 Posts
