1 - 3 of 3 Posts
2004 speed trip- I noticed that the front forks have a lot of sag(2inches) this could have been from being tied down to long in moving truck or to many wheelies i do not ride bike much but have noticed this when front end was lifted off ground the last time. is this something someone has seen before. will a pair of 2001 forks work??(on ebay) are the inside spings or cartrage? any help would be great thanx.
Static sag is adjustable. If the rider sag is too great, you can replace the springs.
Race Tech has a good chart on it's website so you can determine which ones are needed.
thanks for the info. My preload adj make no diifferance to sag no matter what i do. i guess i will have to take apart and see what is broke inside. i did check out race tech, springs are cheap hope it is that.
1 - 3 of 3 Posts
