Having some problems with a daytona 600. The gauges turn on and off. They seem to stay on most of the time while riding, but in neutral they turn off and on. Any ideas?
....... Before doing that, however, I would check the battery voltage at the terminals while the engine is off and while running to see what kind of charge you are getting.[/FONT][/COLOR]
You should really start your own new topic.. look at the date of this one..Hi guys, having the same problem. Have replaced the regulator and done the wiring mod. Get a constant 14.4 v all the time even at idle... but as soon as the revs drop, instrument panel drops out.
Sounds like it's not a common fault, so I'll start going through all the connections on the instrument panel.
