This is going to be hard to describe because I cant seem to find any pattern in it. So im going to give you some examples. It seems to be getting worse, but ive been having this issue for over a year with some new symptoms developing recently.
Bike is 04 t100, mostly stock and no modifications to the drivetrain. 30k miles. Owned for since 2014 with only 2k miles on it then.
Stalls like you hit the kill switch. ALWAYS restarts with no issue or hesitation. Cold or operating temp doesnt seem to make a difference. If anything its better when warm.
While sitting at a light (or my driveway), idling fine at 1200rpms then will just die. Hands off throttle, in neutral, clutch out. Might do it once every once in awhile like once at 10-15 lights. might do it 3 or 4 times waiting for the light to change.
While applying power from a stop, feathering clutch out while taking off. again, might not do it for 30-40 miles then it will pop up. This is the one that is going to get me as sometimes Im applying power around a corner and when it stalls the bike almost goes down. When it does this im fast enough that I can pull in the clutch and give it more throttle to keep it from stalling. But its not fun.
Something recently new in the last few days is that it will "stall" while riding consistent speed. Today it was 55mph 3500rpm, top gear and it cut out several times in 10 seconds. I watched it drop about 500rpms and lurch the bike forward. Im not sure if it "recaught" or if it "pushstarted" itself. This is a 10th of a second event. Just enough to change the weight disposition of the bike/rider and then the power is back.
Sometimes sitting idling it will do something. Like an internal backfire? I dont know how to describe it. But again, it will drop rpms and I will feel the side covers almost "kick" in my knees. Its done this since purchased at only 2k miles.
Sometimes it will feel like it "hiccups" when I hit a bump. But maybe once every 400 miles.
The other day after my ride home, 35 miles, I pulled up in the driveway, put it in neutral, let out the clutch, put side stand down and when I rocked it onto the side stand it stalled.
Im feeling this has to be electrical, but its so random. Some days better than others. I cant make it do it or effect it in any way.
This is so vague....I dont know if we can get anywhere.
