I was wondering if there was another brand of footpeg that would fit on my 2002 tt600? (such as Honda, etc.)
I'm in need of a quick fix so I can ride this weekend...and Triumph parts are hard to come by in central Cali, US. I have already ordered a pair from the UK, but let me know if another brand with fit! Thanks...
Pat D
when the wife broke one of hers, i drilled out a passenger peg,and put a zip tie around the hinge(worked like a spring)that got her riding again, while we waited for a replacement,I think kawi is the same,but not sure,I think most pegs are made by the same manufacter in certain years
I forgot to mention I had drill a small hole in the end of the peg and put in a small screw in to use for a stop, the passenger peg has a square end not a taper like the original
I have heard of that bodge, and also using Buell footpegs. The problem with Buell footpegs is that the mounting pin hole has to be enlarged a bit to work, but you get slightly lower footpegs with them.
