Went to start the bike the other day and would turn over but not fire up...Fuel issue...No relay click so I replaced it with a brand new relay for £22...HOORAY it clicks when I turn the ignition on but hold on I can't hear it priming..
Fuel pump as gone I thought so I bought a brand new one for £120 and banged that on thinking what a clever bloke I am but guess what...Still not priming...
Done continuity tests on fuses and the electrical connector on the fuel plate and all seems good...
The only thing I can think of now is to drain the tank remove the fuel plate and check if the electrical connector is actually providing power to the fuel pump when its actually joined together..
Any ideas and how likely is it that electrical connector is the issue???
