1 - 13 of 13 Posts
I was commuting to work this morning when suddenly, without warning, I lost all throttle response. I knew it wasn't gas - the couple of times I ran low and had to switch to reserve, it coughed a bit first. When I pulled in the clutch to move over to the breakdown lane on the right, the engine was just dead. It turned over when I pressed the start button, the kill switch works just fine, but it wouldn't fire. I had to call a tow truck to take it back home.
When I get home from work, I'm going to check for spark - it has gas, it has air, it doesn't seem to be a mechanical problem, so it must be spark; now, to figure out what the problem actually is.
757098
2016 Thruxton 900
Hey man - a small consolation having such a beautiful bike to stare at whilst waiting for the tow truck.
If all was going good beforehand, hopefully its something simple like a faulty electrical connection or blocked carb not getting fuel into the engine.
Start by checking ignition system connections, especially the ignitor plug under the seat. Unplug it and re-insert it, see what happens.
And put the battery on a Battery Tender or similar when you're not working on it so it stays charged when you try to start it.
You can also try starting from a non-running car battery just to see if that works.
I went through a similar scenario a few years ago, and in the end, the issue turned out to be a failed ignitor. I replaced it with a Procom at half the price of OEM.
Your symptoms sounds similar to what I dealt with last year. I'd start trouble shooting starting at the crank position sensor moving on to the coils then to the igniter.
Haha, thank you! I did confirm that there is no spark by pulling the right one and holding it against a bolt while cycling the starter. From the state of the plug, I at least need to replace those. Ill start checking the other things one by one tomorrow.
I had a similar problem on my 2007 America about a month ago. My bike just died on me after about 15 minutes riding while I was commuting to work, I would leave it for 10 minutes and have a cigarette then the bike would fire up and I could finish my journey which was only around another 10 more minutes. This happened for four mornings, the strange thing was at the end of the day I could ride home with no problems. On the Friday morning I took a spare plug with me so when the bike cut out I could check for a spark and sure enough it didn't have one but on this particular morning the bloody thing just didn't want to start again. I got the bike home eventually, lost a days work mind you, and I checked the resistance across the connectors on the pick up coil. apparently you should be getting around 600 ohms when all is good, I did get the bike started and when the engine was warmed up I was getting a reading of around 770 ohms so I changed the pick up coil and sure enough the old bugger runs lovely again.
Pick up coils are cheap as chicken nuggets and incredibly easy to change so there's a good chance this is the issue you are having with your bike.
Take a look at this, its the ignition sensor
Discussion Starter · #9 ·
Ok. It's not the CDI, and it doesn't appear to be the coil. I've had the TTP BlueFire CDI and coil on for a few years now, but I kept the stock parts; I put the stock parts back on this morning, and still nothing. No spark. I used a multimeter and checked both the red (positive) wire that plugs into the coil, and it has continuity to the positive terminal of the battery. I checked the yellow/black wire that plugs into the coil (negative) and it has continuity to it's other end at the CDI.
I don't know where else to check now. I was really banking on it being either one of those things.
Discussion Starter · #10 ·
Well, well, well. I guess ya'll were right about the CPS. It appears that it broke off its bracket and got chewed up a bit. That explains why it wouldn't start after cooling down like others had.
New one on the way.
Glad to see that you have got it sorted. Thanks for posting the outcome. :)
1 - 13 of 13 Posts
