Hello-
I have a 2000 Speed Triple, and I have a speedometer problem. I searched, but I didn't find a problem exactly like mine. Up at the top of the cable (where the cable enters the speedo cluster), there is a "collet" that hold the cable into the speedo cluster. The collet basically broke in half causing the sleeve to slide down and rendering the speedo/triptometer inoperable.
Is there a place to get a replacement collet? Will replacing the collet fix the speedo/tripto?
Thanks in advance
Thanks in advance
