1 - 7 of 7 Posts
I have a 71 triumph bonneville and am converting the cables from the dual pull to the single pull my question is I was going to use the choke stock plastic splitter and was wondering if there is a difference than the plastic one compared to the metal one is there a difference in the travel lengths inside the splitters?
Never heard of a metal junction box.
Mine has the plastic 60-0685, (244-104).
This is the only junction box listed from two suppliers and is described as air/throttle junction box.
Bear in mind, you will need the appropriate cables and adjusters.
http://www.tms-motorcycles.co.uk/store/products/list.asp?cat_id=113
http://www.tri-corengland.com/cgi-bin/sh000002.pl?REFPAGE=http://www.tri-corengland.com/acatalog/12004_to_366011-12.html&WD=junction box&PN=60-0531_to_60-0747.html#a60_2d0685#a60_2d0685
The choke slide lifts more than the throttle slide,so there's no problem.
You can run one cable from your existing twistgrip,if you wish.
I've got a couple of brass junction boxes,so they do exist.
If youve got a soldering iron,you can make the cables fit.
I think that's what I have to do is make my own cables. I'm a little concerned about doing that because I have never done that before. Do I use regular solder on the ends of the cables?
Here's a Lunmad vid that might help (he has a metal 2-1 as well). Part 1 and 2 are helpful too:
1 - 7 of 7 Posts
