1 - 3 of 3 Posts
OK first post.
I own a 1999 speed triple. I just bought it back from a guy I sold it to a year ago. I'm happy. I took it in for a service and had the valves adjusted. I put an Ohlins shock on it. New clutch perch lever and Brembo GP master cylinder. NEW tires, New gauges (digital) and a few other things. I'm Very Happy!
It litteraly blows oil out the tail pipe now. I'm very very sad.
It starts doing once the bike gets warm. and its really bad at about 2000 RPMS.... I'm going to the dealer today to get their advice. Any adive from my fellow triumph lovers would be great.
Matt
Motowheels.com
Welcome Matt - sorry for your troubles, otherwise your bike sounds like it would be a gem.
Can you give us more details on the oil issue - is it smoking (colour?) or are you saying oil is literally dripping out the tail-pipe?
Is there any oil in the airbox drain if you pull the plugoff the end of the tube?
Can you pull the spark plugs and see if you can tell which is the offending cylinder.
Incidentally what kind of digital gauges did you install?
1 - 3 of 3 Posts
