1 - 3 of 3 Posts
Picked up a 955i on the cheap and trying to get it running. Pulled the injectors and they are all spraying when cranked over. All three cylinders have spark. Cranks over but wont fire. Pops every now and then. But mostly just cranks and cranks but doesn't start or really even seem like it's trying to. Even tried starting fluid still nothing. Ideas on what to check next?
Check the Crank Position Sensor gap - should be 1mm (0.040")
If you're new to Triumph EFI do not open the throttle when starting - leave it alone
If you have tried starting with the throttle open, cylinders likely flooded
You're going to want to pick up a Software tool called TuneECU and a cable to connect to your bike - that will give you a LOT of diagnostic information that will help in tracking down the problem.
1 - 3 of 3 Posts
