1 - 15 of 15 Posts
Those of you with this year bike know the part I'm talking about. It's a plastic duct that attaches to the front of the air box and faces forward to connect with a rubber tube that then fits into the front fairing. The rubber tubes are still carried by Triumph, but the plastic ducts are not. Of course the bike can suck air through the holes without the duct work, but I did want to replace those.
If the part isn't available and maybe yours fell off anyway like mine did, apparently, what sort of hose or tubing did you use to replace it? I'm about to start looking around for something.
Discussion Starter · #2 ·
So I went to an auto parts store and found some radiator hose that fits the rubber tubes I have. I cut it in half and will try fitting it in tomorrow. There's an internal spring to the hose I will cut up and try using to keep the whole duct work together.
· Super Moderator
1 - 15 of 15 Posts
