1 - 10 of 10 Posts
Hi everyone. Just getting last few bits sorted on bike and down to fitting side fairings and belly pan cover but am missing mounting brackets. Anyone know where to source these or can someone take a pic of them so I can fabricate them myself. Any help would be appreciated. Cheers J
1998 T595 Daytona 2014 Kawasaki Ninja1000ABS
I have a '98 that's been off road for the past 8 years. It's in my garage, I can remove the two side fairings and take pics for you. It might take a few days to get to, but I'll get to it. The side fairings and belly pan are held on with some bolts and mostly Dzus fittings. World of Triumph doesn't list the brackets in their part diagrams, just the fairings and fittings. You can give that a look as well.
Here are some initial pics. The first two show the connection of the infill panel to the top of the side fairing. Front is a bolt to a bracket on the center fairing. The other hole is where a Dzus fitting attaches the infill to the top of the side fairing. The next pic show the front of the side fairing attached to the side of the center fairing, all Dzus fittings. Then a pic showing a center bolt through the fairing and then the lower bolt hidden by the belly pan. Next shows all the Dzus fittings that attach the belly to the lower edge of the side fariring. Next, right side of bike shows the backet under the oil fill window that attaches the end of the pan. It seems to be welded to the case with a right angle tab and then just runs straight down. Last pic shows the left side bracket that attaches to the end of the pan on the left side. I can take off the fairings to show how the center and lower bolts attach to the bike. Not the best pics, but hope this helps a bit.
Hey mate thank you for this, thats a huge help. No rush on pics for the side fairing brackets mate, just when you get to it. Cheers👍
Nice weather here today so I managed to remove the left side fairing to show the center bolt bracket and the lower bolt bracket. I'll get to the other side but it may be identical. First pic is of the center bolt and the second the lower bolt that is hidden behind the belly pan.
Good luck. If you were in the US I would take them off and ship to you to fabricate copies. I hope to get my '98 back on the road at some point.
1 - 10 of 10 Posts
