On the fender I'm not inclined to make additional holes in it - I know it works with the OEM caliper so I'm back to looking for one of those.
On the caliper, the bleed screw takes a 10mm wrench, it does not have any name cast into it. The stock brake line felt fine, but this had been installed using non-metric brake lines before so not sure if anything was done at that time (but I doubt it). Since M10-1.25 is "close enough" to 3/8-24 it could be metric. I'm not really comfortable with "close enough" on the brake system, so another indicator I should be looking for a replacement caliper.
Or maybe turn it into a chopper and remove the front brake entirely... LOL
