Hi, I am trying to get the center stand working properly. The stand was bent when I got the bike, probably from starting the engine while on it. I managed to straighten the twisted connecting tube with lots of propane heat.
The stand is otherwise ok, but I had to make a new footlever since the original Siamese exhaust was changed to twin pipes at some time.
The ears on the frame has seen some wear (a little more than a mm), which make the stand lean too much back. This in turn makes the stand slide on smooth surfaces when the bike is pushed off it. A photo is attached, showing how the bike currently sits (bike is complete now).
Since the ears have little damage, I would like to build up the contact area on the stand rather than do anything to the frame ears.
My question: Is it possible to get information somewhere on how the bike should normally sit on the centre stand? I am thinking of how many degrees the feet should lean back from vertical when everything is to spec.
Thanks, Helge.
Thanks, Helge.
