1 - 2 of 2 Posts
Hi new member , from ohio I purchased a 1972 650 bonneville which I have is in a 71 of build with the original frame seperate.
I was wondering if any one had any advice about chopping the 71 frame and doing a hard tail bobber I have heard that it makes for a unbearable ride ?
I would like to a full rebuild and swap the +vg to -vg and run a battery eliminator with all led bulbs .
Not sure of the minimum requirements for the ignition system ( points and dual 12v coil, or 6v) at idle vs stator output if any one would happen to know that information it would be greatly appreciated , or any suggestions on this setup
Thank you
1 - 2 of 2 Posts
