81 - 100 of 124 Posts
Discussion Starter · #81 ·
I just went out and hit them quickly with some Quik Glo so I could get a better look at the markings. With some proper elbow grease and the right process, they might clean up really well.
I did have some Dunlop rims rechromed by a supposedly reputable company, and depite being told not to, they polished out the makers name! I might as well have bought some of the decent quality pattern rims that are available.
If you can, rescue what you have!
That looks like a West Coast 1965? Did it come with the tank rack fitted? I have a '65 T120C TT awaiting restoration and was unsure whether to fit the tank rack or not. Some people say that the racks were not fitted to the TT Specials, or were removed by the dealer prior to sale. It would be interesting to know if your's had it from new.
My 1964 T120C had 4x small rubber bungs where the screw holes were for the parcel rack..
Discussion Starter · #86 ·
So, I have begun to disassemble the TT in preparation for restoration. I started a project thread over on BritBike about this as well. I will come back and update here when I can. Probably going to be slow going and done as time allows. Here’s a few pictures of where it is. The Corbin-Gentry seat is a little worn but could certainly be refurbished and used as a nice period piece.
Next task is getting the engine out. Hope to have this accomplished in the next few weeks. Definitely want to get it out of there and inside before the cold weather sets in.
Discussion Starter · #87 ·
I will also add that the chainguard on these bikes is quite a diabolical contraption. I don’t know who designed it but they should call the engineering school they attended and ask for a refund. It was quite a Rubik’s cube to get out of there past the rear fender and wheel. I had to take the shock out to gain clearance to remove it. Maybe I am missing something, if so I would appreciate an education.
Discussion Starter · #91 ·
Top end is off. I did a quick check of the pushrods for runout, all were less than .001”. Looks like the original 11.1:1 pistons. I will inspect the rest of the parts as time goes on. Right now just want to get everything disassembled and sorted. I will have many more questions as I progress.
Wood Gauge Clock Watch Measuring instrument
Wood Gas Machine Auto part Engineering
Oval Wood Font Close-up Jewellery
Sewing machine Motor vehicle Machine tool Household appliance accessory Engineering
you would feel better about the triumph chainguard if you also owned a BSA
Discussion Starter · #97 ·
This steering head nut seems to be an oddball. 5/8W is loose, 1/2W fits very snug with some light tapping. Tried to break it loose but no luck. Stopped to ask before going too far.
What is the proper way to loosen this hardware without doing damage? Thanks.
Wheel Tire Crankset Automotive tire Motor vehicle
Bicycle Bicycle frame Crankset Automotive tire Bicycle tire
