OK Stuart - bordering on the esoteric and I think I get some of this. Give me a few more years (if I've got them!).Hi,
Not necessarily? The change was advised by Umberslade Hall mainly because the 'no-hole' rocker was cheaper to make, but is also slightly stronger. Assuming you don't expect to thrash the 'nads off your rebuilt engine at every opportunity, the rockers in your photo. should be fine?
Changing to 'no-hole' rockers is something of a can of worms:-
. the rockers-'n'-washers assembly diagram in the 650 workshop manual becomes wrong, you have to use the one in the triples manuals;
. if you reuse the existing rocker shafts, they need an oil transfer groove or scroll machining along them;
. the lateral position of a shaft within the box and rockers could be a problem when the domed nuts are tightened.
Mmmm ... there's better design, if they're available to fit:-
. In theory, the mushroom head allows for the rocker-arm moving in an arc while the valve stem moves in a straight line. Snag with the mushroom-head is it's still point contact on the end of the valve stem; if the adjuster has to slide across the valve stem during actuation, that force is concentrated in one small area in both adjuster and valve stem tip.
. @DMadigan Dave developed an adjuster nicknamed "elephant's foot" for the triples from those used by Porsche and by Mercedes-Benz on the 190 engine. Each adjuster is in two parts, threaded part in the rocker, circular part covering the entire valve stem top, joint between the two takes care of the difference between rocker arc and valve straight movements. The advantage is, if the rocker arc imparts any sideways force, it's spread over the whole adjuster 'foot' and valve stem tip with the chance an oil film can survive between.
Dave makes his for the triples so they can have a 5/16"-24 thread to match triple rockers - Porsche and MB adjusters are M8 Fine thread, close but no cigar and, rockers being hardened, rethreading triples' rockers for metric adjusters needed two or three taps.
What I don't know is if Dave makes his adjusters to suit the 5/16"-26 thread on pre-'73 twin rockers. However, now I've name-checked him, the Forum software will show him a link next time he checks in.
Or, if you must change the rockers, I don't know whether 750 rockers - with 5/16"-24 adjuster thread - would fit?
Or use the mushroom-head adjusters you've bought, with valve stems shortened for lash caps? Any later wear, the whole valve doesn't have to be changed, only adjuster and/or lash cap.
Hth.
I’ve another ask. I’ve looked at the ball end of the rocker arms and the ball surfaces seem smooth and polished so I don’t believe I need to attempt to replace them. I am curious as to why the adjuster ends are so gouged up and pitted. It would seem to me that they shouldn’t wear in this manner. I’d appreciate any insights as to why these might be in this condition? Thanks.
