I got the cases split today. I still have some challenges ahead. First off it was difficult getting the cases apart, I had to heat them a bit before I got some movement. There seems to be an awful lot of gasket cement and other goo on all the joints.
So, the intake cam is not original. I’m wondering if any forum members might be familiar with this brand - Megacycle Cams from California?
I wasn’t able to get the rods off the crank. These say “JRC” and have 6 point star bolts. I got one loose but the other won’t budge with a long breaker. Any advice on how to get these off - many thanks! Do I finally need to get an impact driver?? Plus - any knowledge of these rods? They are obviously not original and I imagine I need to determine if they are still OK to use in the rebuild. I’ve got to get them off first. And one more thing - these do not have bushings in the small end so not sure how to manage that when I build it back.
I could not remove the exhaust cam because I can’t get the key out of the end. It looks almost like whoever assembled the beast deformed the top of the key a bit. I’ve tried picks and such to get it out. Any ideas on how to remove this so I can take a look at the cam?
I’m curious why someone would have filled in the hole with some compound (silicone?) on the end of the smaller transmission shaft?
One end of the crank is buggered a bit from some PO. Not sure if this is still ok for the rebuild. Notice the bearing is still on the crank. I’m wondering what kind of puller is needed to get this off the crank?
There is a number engraved on the flywheel of the crank - #10595 - any idea of what this is for? I am impressed by the weight of the flywheel!
So, I’ve got to get the rods off, bearing off the crank, then I should find someone close by to do some hydro-blasting.
Thanks for any comments or advice!!
