Hi,
troubleshooting a failure to start
Start with pulling the plugs and checking for spark.
Next, check to ensure the ignition timing is set properly. Before you move on, swap the two leads from the ignition stator plate.
If the plugs are sparking, Paul is thinking of a problem with the the similar Boyer-Bransden EI:-
. Bransden sometimes connects the Black/White and Black/Yellow wires incorrectly on the B-B equivalent what the Pazon fitting instructions call the "ignition trigger";
. when the BW and BY wires from what Pazon calls the "ignition module" are connected to the "ignition trigger" colours like-for-like, the spark timing is miles out;
. fwiw, I've not known or heard of Pazon making the same internal connection mistake on their "ignition trigger"?
Otoh, if the plugs are not sparking:-
single point negative ground
. Have you connected the Pazon "ignition module" White wire to this or directly to the battery -ve terminal? Fwiw, I would've done the latter, through a 5A fuse.
. Two separate coils, "ignition module": Black wire is connected only to one coil's -ve terminal, Red wire is connected only to the other coil's +ve terminal?
. Otoh, only one coil with two HT leads, "ignition module" Black wire is connected to the coil's -ve terminal or wire, Red wire is connected to the coil's +ve terminal or wire?
. Wire to the ignition switch or separate kill switch is connected only to the same coil terminal or wire as the "ignition module" Red wire?
. All switches on, you can measure battery Volts between battery -ve and every connection from coil +ve (second of two) through all switch connections to battery +ve?
If making these latter checks, be aware Pazon does the the same as B-B
- having powered-up the EI and coil(s), if the ignition module doesn't "detect engine movement" - signals from the ignition trigger because the exhaust cam is rotating the "magnetic rotor" - after a few seconds, the ignition module will cut power to the coil(s) ... after which measurement between battery -ve and anywhere else become meaningless ... The only way to restore power to the ignition circuit for another period of testing is either turn the ignition switch off and back on again or kick the engine over ...
Hth.
