Hi rats,
A friend of mine came bearing gifts a while ago. He knew I was a huge Triumph rat and pretty much gave me a 1963 Triumph Bonneville T120. The only problem was, it was in over 100 pieces.
But of course I won't let that stop me. This will be my second engine rebuild, the previous was a much smaller and simpler motor on a MZ TS150 so I could definitely use your advice and guidance on this one. I've started watching the Lowbrow Customs Engine rebuild videos to get a bit of knowledge about rebuilding these engines but I'd love for you guys to look over the parts and let me know what I should check and which parts I should definitely order new replacements for, since these parts have obviously been sitting for a while after being taken apart. I can take more pictures if needed.
The engine block is broken above and below the chain sprocket area. I assume the chain got loose and broke those pieces off, which is most likely the reason this was all taken apart. There is no crack into the block itself thankfully. I was thinking about having a welder try to make the section above the chain sprocket look better, but just leave the below section broken, since it's a small piece and I don't see any good reason to add that back.
The frame that came along with this has been turned into a bobber, which is not really my thing but I've grown to like the idea of having a bobber since getting this. The VIN on it matches the engine btw.
I noticed the conrods are not marked so I have no idea which one was where, the guy from the Lowbrow customs video said it was very important that they go back to where they came from, oh well 🤷♂️.
Here are some pictures of the parts.
Gilli
Gilli
