Hi Guys,
I've been busy this winter trying to get my own sevicing done. So far I've managed to change the oil and filter, spark plugs, fuel filter, changed to a K&N air filter. I've stripped and cleaned the front and rear brakes (what a difference having all the pistons moving - great improvement), unsiezed my chain adjuster, and am nearly ready to look at the suspension.
I've read a lot of posts referring to the use of the 18t front sprocket and would like to ask a couple of questions before I jump in the deep end.
Firstly what diference does it make to the power take up. I ride a lot in all weathers and would be concerned that fine throttle control in wet or icy/greasy/diesel covered roads may be more difficult.
Secondly are there any issues with the chain length. I will be doing the change at home using my centre stand and home tool kit, and wouldn't fancy having to chop out a link or two.
Thirdly does it affect chain life due to the extra force exerted by the smaller circumference pulley.
I'm really keen to do this, but just need some reassurance.
Regards and thanks,
Martin.
PS Can the Forum member I had the pleasure of meeting at the PSNI Trek at La Mon hotel get in touch. Due to too much Guinness I forgot your name.
Regards and thanks,
Martin.
