Hi,
As you may know, the Sprint upto VIN 16921 shared the 6-spoke Akront wheels along with the Trident. Then from VIN 16922 the Sprint was fitted with the 3-spoke Brembo 17" wheels (as fitted to the Speed Triple, etc....). This change also happened mid-VIN range to the Trophy and Daytona.
I have seen several 'older' Sprints "updated" with the later 3-spoke Brembo wheels - so the answer to your question is YES, it can be done.
I am not sure if it is a straight swap, or if it is more involved. Unless somebody else replies, I would contact Sandy at Triumph'ant - they have offered several T300 models with a cross-mix of wheels. (See Triumph'ant ).
If it helps, I can send you some part fiche snaps for the Sprint showing both wheels & fittings? Send me a PM with your email address, so I can send you a Word attachment. However, you should get a straight answer from Sandy.
Hope this helps?
Please update this thread with any information you find out. Thanks.
Geoff
:wink:
[ This message was edited by: GeoffE on 2007-01-03 17:08 ]
Hope this helps?
Geoff
:wink:
