1 - 10 of 10 Posts
I ride a 2016 Triumph Tiger 800 XR in upstate NY. I had a battery go flat a couple of months ago. It charged up fine, but the engine fault light comes on sporadically. It comes on, stays there for a few rides and then goes off. Then it comes on again. The code I can get from the bike using the up-arrow+information buttons method is P1698.
Any suggestions as to where I should look here?
2022 Triumph Bonneville Street Twin
What is your battery voltage?
1. Key off
2. Immediately after turning key on
3. While idling
4. At about 2,000 RPM
1. Key off
3. While idling
This is the original Triumph battery. It's a 2016 model year bike that was put on the road in April 2017.
1. Key off - 12.96V
2. Immediately after turning key on - 12.65V
3. While idling - 14.27V
4. At about 2,000 RPM - 14.33V
All voltages are good. Probably ought to start checking all connections related to the ECU.
A. Disconnect connectors, reconnect.
B. Check wires to connectors for any sign of weakness.
C. Ensure that harness/chassis grounds to engine / transmission are not more than 0.1 ohm resistance.
D. Same with both ends of battery negative cable.
Discussion Starter · #7 ·
I bought a license to use TuneECU and used it with my cheap automobile Bluetooth ODBII reader, and it worked first time! I cleared the 2 dtc codes found in the ECU – one relating to the battery having been flattened and the other to a fault in a 5V line from the ECU having failed, another effect I suspect of the flat battery. The software also helped me reset the service interval. I LOVE this app! Now I just have to hope that the fault codes stay cleared!
My suggestion would be to get a new battery. A weak battery will throw all kinds of codes. But, don't get a Deltran Lithium battery. I went through all kinds of hell with one of those and they just will not work with a Triumph. Other lithium batteries may work but not a Deltran. I finally just bought a new GMT battery. All problems went away.
Discussion Starter · #9 ·
I'm coming around to your way of thinking. After I reset the codes the bike behaved for a couple of days. Then I pulled it out of the garage and parked it on my driveway. An hour later I sat on it to ride and it wouldn't start - lights all up and bright but no starter motor. After 5 minutes of poking at it, it started, as if nothing had happened except the engine light was on. 3 clean starts later the engine light clears. How does a flaky battery post sound?
Discussion Starter · #10 ·
I replaced the battery a few days ago. One good ride and several garage starts and stops and all is well so far. I'll keep you posted.
1 - 10 of 10 Posts
