401 - 413 of 413 Posts
That is exactly what I understood. I saw and felt this with my hands when I first greased the pistons.
Thanks you Terry for the picture representation. This will bring a clear representation of what is causing the issue.
Santiago might be able to use this picture in his case investigation.
I heard from Santiago about 2 hours after I put in my complaint on the NHTSA site about a month ago, and he was still in the process of finding enough data, and working with Triumph to figure out if there is a problem that needs to be addressed. I'm paraphrasing, but that was the gist of it.
However I did get a call from my local Triumph dealer near Atlanta this past week, and someone from their corporate offices asked that I bring my Thruxton to the dealer to have a look at it. I dropped it off this past Saturday. It seems like something is happening between NHTSA and Triumph, since I had not contacted Triumph or the dealer about the brake issue. When I have more information about what the dealer finds I'll update the group.
Ok great, i found him very easy to contact at 1st then the communication just came to a sudden stop about 2 months ago ?
Is your bike still under warranty???
My dealer has not called me at all, even after putting in the claim 3 years ago.
I remember they comp the 2 brake flush few weeks after warranty expired. I have no receipts, because dealer said it was "comp".
My dealer bled the brakes the very 1st time i mentioned putting in a claim, but this made no difference at all to their operation & he told me that Triumph would do no more to help & they believe there is no issue...After this, i decided to bleed the brakes again & discovered that the shop had done the bleed nipples up ridiculously tight....Then, after bleeding them "which again made no difference" i emailed the dealer & told them i wanted an official claim to be forwarded to Triumph....Soon after this they contacted me & said Triumph had told them to bleed the ABS system on my bike, so i agreed to let them do this but supplied them with a lot of evidence from this forum so they could see that the problem has nothing to do with air in the system & everything to do with the caliper pistons...I also made a point of telling them not to force the bleed nipples so tight a 2nd time because i did not want the calipers damaged...When i picked the bike up from the shop the brakes were operating correctly, so i said thanks, but explained that this was unlikely to last...The following day i decided to check how tight the bleed nipples were by cracking each side once & draining a tiny bit of fluid out of the "over full" master cylinder...The bleed nipples were so tight that they were creaking when i tried to loosen them...I then made the foolish mistake of letting the dealer know that i was annoyed by this, and i was concerned that the calipers may have sustained damage because of their heavy handedness...The dealer told me that i had probably let air into the system "which is obviously rubbish" and he would not warranty the brakes anymore because i had tampered with their work...and he obviously never responded to my concerns...The brakes have now been operating correctly for nearly 2 weeks since that conversation, so time will tell ! If the brakes do return to their previous state of operation, i will take it up with Triumph & continue to annoy them until something is done to resolve the problem...
Yes - I bought the extended warranty, though the service manager didn't know that when I dropped it off. He mentioned something about a 'goodwill warranty' if they found something wrong, so he obviously had not checked yet. However, I did not bring the bike in on a warranty claim, and had not even contacted the dealer directly. The dealer called me after the Triumph corporate technical people contacted them to have the Thruxton brought in for a look. So I guess NHTSA must be working with Triumph in some way, and Triumph wants to have a look for themselves.
I am just outside Atlanta, which is where the corporate offices for Triumph are (I think), so maybe that has something to do with it.
Really I don't expect much to come of it. There's no way in hell Triumph is going to foot the bill for the proper pistons, new seals, and the labor to put it all together. They'll probably bleed the brakes and call it good, which of course it won't be. A couple rides (and some brake pad wear) later it will be back to the same old over-travelling lever. I've bled the brakes myself, including the ABS on this bike before, and that's exactly what happens. It's a temp fix at best, cleaning and lubing pistons might help a bit more, but it doesn't solve the issue.
I fully expect to be putting down the $$$ on new coated stainless steel pistons and a seal set. And I'm kinda ok with that, because $500 to fix the brakes is way cheaper and less painful than crashing.
At least we know there is a solution to the issue, Jeevs and I have proved the fix.
Before I hated the bike, because it was unrideable with that first long pull. Now, I am enjoying it ever since I fixed the problem.
I just received a call from Triumph and they are going to contact my local dealer and "Do whatever it takes to fix the issue". He could not elaborate but I am willing to give it a shot. Maybe they will replace the calipers or seals/ pistons. I doubt it, but it is worth a shot before I tear it down and fix it myself.
It will be a few weeks before I can get it into their shop, but I will keep the forum posted.
Update on my '17 Thruxton. The dealer has had it for a month, and they are finally to the point they are ready to start road testing it. Weather has been kind of rough here, so hopefully they'll be getting it on the road this week. I know they rebuilt my calipers and replaced the master cylinder, but not sure if the pistons were included in the rebuild. I'll have to wait until I pick it up to find out. I'll update the thread when I know more.
I would say that if the same OEM pistons are used when they rebuild the caliper, than it is likely that the same problem will develop. Thought it was worth a try to see if Triumph can figure out the problem and fix it, but if they don't I'll just do it myself.
From talking with the service manager I get the impression that they're sort of taking the shotgun approach with the issue - change everything and hope something fixes the issue, rather than really finding the root cause and addressing it. I really tried to impress on him the issue with the aluminum pistons when I dropped it off, but I think that Triumph is calling all the shots on this one, not the dealer. So if they're replacing parts they're probably using Triumph OEM, and unless Brembo has made a design change in the caliper or pistons they are supplying, I'm likely going to get the same pistons it originally came with. Likely that they'll replace everything, put new pads in, ride it 50 miles and say that it's working just fine. Then I'll ride it 1000 miles, wear in the pads, and have the same issue all over again.
Not sure that the troubleshooting methodology is working very well on this one from Triumph's end. That said, I'd like to thank all the folks on this board to did a great job troubleshooting and finding the true cause of the braking problem. Well done!
If they're obliged to use Triumph OEM parts perhaps you can suggest they try these DLC items which, if the website is to be believed, are now fitted as standard to the Thruxton R.
Or perhaps they might consider using the Brake Tech items which Red Baron has had some success with. There was even a suggestion that the pistons used in the TFC Rocket 3 are different to the standard Rocket 3 and as a consequence don't suffer the soft initial first pull issue.
