1 - 12 of 12 Posts
So, thinking someone here will have some wisdom, as I'd really like to narrow down the scope of the problem, rather than paying shop rate for a mechanic to scratch his head and make phone calls to Triumph.
I had the 15K servicing done, and a few days after I got the bike back, I noticed that my rear brake is, well, pretty much not working at all. The brake lever goes all the way down to the stop with no resistance as you'd expect from a hydraulic system. However, there isn't a fluid leak or other indication that brake fluid is going someplace it shouldn't.
The behavior doesn't change, if the motor is on, or off. The ABS system doesn't see a fault (when you start the bike and get rolling, the ABS light will go out the first time you use the brakes).
So what I'm thinking, is there's some kind of solenoid that is designed to shunt the brake pressure to keep the rear wheel from locking up under braking, and this solenoid is stuck "open" so that hydraulic pressure never reaches the caliper pistons.
Has anyone else run into this problem, and if so, what was done to fix?
Thanks, y'all. :)
I don't believe in coincidences like that. It's almost always a result of what was just done to/on the bike.
I'm not sure if that service changes the brake fluid, but it sounds like there is air in the system.
That's what's weird, I've ridden a bike with air in the line, and while it was spongy, you still got the impression that there was some pressure. This, there's none at all, so there must be a really big bubble in the line. If it wasn't ABS I'd be doing my own brake work, but putting an electronic gizmo into my brake circuit has me second-guessing prior experience.
Who did the service? If the dealer, then have them fix it.
If you do most of your own maintenance, I suggest getting DealerTool. You can activate the ABS switch to properly bleed / flush brake fluid.
  • Like
Reactions: The Hornet
Thanks, y'all. :)
I've got the same problem right now, how did you fix it?
Did the service include removing the rear wheel or brake bleed or pad replace ? If the service didn't create the problem you may need to grease the caliper/carrier assembly.
Ger,
Hey, When that happened to mine (2010) , the brake cylinder was bad, needed rebuilt. Since you were at a dealer, would check on what they did. Sounds awfully strange.
ride safe
Dan
ABS....I thought required a dealer tool to bleed properly.
Edit: As VA posted earlier.
"Dealer tool" is available for anybody to purchase, I think it's based on the Triumph dealer software hence the name.
Although the majority of people now use tune ECU for the same purpose, either will operate the abs for bleeding.
Unless Tune ECU has been updated, it's my understanding that it will not allow ABS switch activation
It works fine on both my bikes but can't 100% guarantee it works on a 14-thunderbird, maybe somebody with the same bike can comment.
The software does get updated often.
I understand the same. I use both TuneECU and DealerTool; DealerTool will activate the ABS solenoids, TuneECU will not.
1 - 12 of 12 Posts
