Anyone ever wired a 12 volt (lighter style) power outlet to your Tbird Sport? Not directly to the battery but connected to the switch wiring so the power is off when the mcycle is turned off.
I have a duplex 12vdc outlet with duplex USB ports that plugs right into the pigtail for my battery tender. That's SAE I believe. Not switched like you want, but simple enough for me.
I mounted mine under the seat too, but I have an Adventurer so no idea how much room there is on the TBS. I simply found a spare lug and bolted it onto that then wired the -ve directly to the battery and the +ve wire I simply pushed it under the blade of the accessories fuse and routed it out through a gap in the fusebox cover.
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
