1 - 9 of 9 Posts
Is this normal? I ask because i was using a older version and got the newest version today because i wanted to adjust the speedo which the older version didn't have. When i opened 1.9.2 i got some error message and when i chose to ignore it, tuneecu opened but wouldn't work and has a red X in the map window. So i deleted it and downloaded it again and this time it works. But i noticed instead of two 02 sensor checkboxes there is only one. In the old version there are two. I assume that Alain just decided there is no need to have a seperate box for each since you would never turn just one off. But because of that error i got i want to make sure that it IS just a change Alain made and not an issue with tuneecu after that bad download. I don't want to download a map till i'm sure this is normal. So is it normal for tuneecu to now have just one 02 sensor checkbox?
it was 1.8.something, can't recal exactly. Thunderbird 1600, map 20310. But in any case i just used it and no problems. I have another question tho. I changed the "speed adjust" under "parameters" like someone else said he did. He said he changed it down 3.7%. I did the same and set it to "-3.7" and while he said it corrected his speedo perfectly according to his GPS, i found it seemed to either did nothing or maybe changed it 1 mph closer at most. Any idea why it didn't work the same as his?
Must be a problem with 192 because i just realized i have a copy of 191 on another PC. So i put that version on my laptop and tried it and it shows both sensors. Either that or the download was bad twice in a row. maybe the internet connection on one side or the other was bad or something.
1 - 9 of 9 Posts
