remember to change the setting you press the lever away from the grip then dial it, then set it back into place and test the pull distance. Mine makes a big difference, worked great when my brakes were a bit soggy I could give more pull and make them work better for me. Scheduled in for the new 5/8 master cylinder though and the drag bolt.
