1 - 3 of 3 Posts
I borrowed this 09 T- 100 from the dealer and I forgot to ask how to remove he gas cap so I can fill the Bonnie up. If I turn the cap counter clock wise it clicks just like on a car. If I go clock wise it turns and seems to lock and doesn't release. Do I push down when turning to release it? Thanks for the help.
It's just really tight, you don't need to push down, just grip it for all your worth and twist to undo it. I thought it was clockwise is tighter (and clicks) anti clockwise to undo it.
You are correct and thank you I went out and got it off. My 04 Tiger is much easier, Uses a:rolleyes: Key.
1 - 3 of 3 Posts
